Hi team,
I’m using the Tutorial to create a new app. Ref : https://developer.dynatrace.com/getting-started/tutorial/create-project/
Step 2 (Create a new project)
According to the documentation a URL to my own environment will be asked but that did not happen. Is that as expected ? See screenshot :
Tony
Hi @tony_anthonis
If you are logged in into dynatrace developer, then the command for creating a new project contains your default(or selected) enviornment and no prompt will pop up.
Anyway, we plan soon to release a completely new tutorial (next weeks) with different guidance so this confusion will be avoided.
Best,
Sini
