Use dims placeholders in Dynatrace webhook payloads for automation
We’re trying to use {dims:} placeholders that we’re using in a custom event in a payload in a webhook integration.
When we add the {dims:} placeholders to the custom event, we see the properties that contain the dims placeholders. But when we add the same placeholders to the payload, the fields of the payload don´t contain the value of the placeholders.
It returns something like this:
[{“type”:“APPLICATION_TYPE”,“name”:“xxxxxxx”,“entity”:“APPLICATION_TYPE-xxxxx”}], “id”: “P-XXXXX”, “pid”: “-XXXX_XXXX”
“propertiesMyProperty”: {dims:MyProperty} “propertiesMyEntityPropertiy”: {dims:dt.entity.custom_device_group.name} }
We are defining the paypload on this way:
“names”: “{ProblemID}”,
“detalleImpacto”: {ImpactedEntities},
“id”: “{ProblemID}”,
“pid”: “{PID}”
Does anyone know if it’s possible using these properties in a payload of a Webhook integration and how to do that?
Elena.
So “Dims” will only work when a dimension is seen by way of a metric event/davis anomaly detection, however, “Dims” is not part of the criteria of payload for the webhook integration.
My recommendation would be to ensure your Dims is in the event payload, then leverage problem details in the integration payload. So if Dims is qualified, it would then show.
