Is there are an automatic migration tool that takes care of migrating SLO’s in the classic to SLO app?
I think there isn’t an automatic migration tool yet. Dynatrace is investigating an automated upgrade flow, but for now you need to migrate Classic SLOs manually (or via configuration-as-code) using DQL in the new SLO app and the SLO Service Public API
Practical migration paths (at a glance):
Convert Classic selectors/metrics to DQL (see the “Upgrade Classic SLOs” Upgrade Classic SLOs guide)
Or, Create/manage new SLOs via the SLO Service Public API or the Terraform provider (from version 1.78.0: dynatrace_slo_v2). Monaco has supported the new SLO API since v2.22.
Hi @SrikanthSamraj ,
Take in account that you can´t migrate all the SLO due to not all metrics are supported by Grail. For example, SLOs for RUM, like UserExperience SLO template, can´t migrate due to this information can’t get in Grail.
Thanks for the useful link, @t_pawlak .
Elena.
