The problem API exposes all the evidenceDetails that are displayed on the Problems page as a rather complicated json object. With the problem nontifications you can push those details in a nice text format:
{ProblemDetailsMarkdown}: All problem event details including root cause as a Markdown-formatted string.
{ProblemDetailsText}: All problem event details including root cause as a text-formatted string
Is there a way to retrieve this text via the dynatrace problem API?
AFAICS there is none and i would have to interpret the json myself if i want to pull problems from dynatrace instead of using a custom notification<
