- Go to Settings > Cloud and virtualization > VMware, and select Test connection.
- In the vSphere web client, go to Event Console. For details, see View Events in the vSphere Web Client.
- Check for events related to the user that is set up in Dynatrace credentials. With the correct network setup and correct credentials, you should expect a pair of UserLoginSessionEvent and UserLogoutSessionEvent entries from the IPs of one or more ActiveGates that have VMWare monitoring enabled and that have tested the connection.
- Check for errors visible in the events. If there is no entry at all or no entry for the ActiveGate you were expecting, check your network setup.
Very useful ![]()
Thank you!
