I’m trying to use a variable from the browser “Session Storage” as the user tag.
Using the “Cookie value” resulted in miserable failure, but I found some inspiration in this thread that tries to do something similar with the “Local Storage”:
https://community.dynatrace.com/spaces/482/dynatrace…
The variable name I can use has this format: company.application.applicationname-web-app.user.
The problem seems to be the strict ‘dot notation’ checking that seems to be enforced, which doesn’t agree with the ‘-’ characters in the variable name:
Any ideas if my concept would even work, or if I may be able to use some fancy escaping to be able to read the variable with a ‘-’ in the name?
Pieter
