Using javascript code on Dynatrace
Hi everyone,
I would like to execute a javascript code to call a database inside Dynatrace and I have seen that in the new dashboards and notebooks I can add external code and execute them:
To do this, do I have to follow some steps? or is it just entering the code as if I were programming in an IDE?
Thanks in advance
Hello soportetr,
Yes you can code directly inside notebooks and dashboards in Dynatrace as if you were a programming in and IDE.
