I’m trying first steps with building a Dynatrace App. Got a demo app and taking my steps from there, but I have no experience in typescript nor nodejs coding.
The Dynatrace JavaScript runtime will provide a compatibility layer for Node.js to improve compatibility with third-party npm packages. This is currently not possible.
On the page about the Dynatrace JavaScript runtime we will add an section about which node modules will be supported.
So currently no node modules are available as part of the Dynatrace JavaScript runtime.
Actually, there are quite some node modules already supported. The content on JavaScript runtime | Dynatrace Developer will soon be updated as soon as all changes are rolled out.
However, node:tls won’t be supported. @r_weber can you tell me what you want to do with this module?
