That is true, but from AG v265 there will be a permanent folder for custom MIB files. The documentation will be updated, but I believe the final paths will be:
Linux: /var/lib/dynatrace/remotepluginmodule/agent/conf/userdata/mib-files-custom
Windows: C:\ProgramData\dynatrace\remotepluginmodule\agent\conf\userdata\mib-files-custom
@Hi@jegron if you manually put MIB files into a directory with the default package it will be overwritten by the default package in the next update. AG restart is required to load new MIB files, because modules are being loaded when the DataSource process starts. The proper way to add MIB files is to the custom extension zip package. They will be deployed and no further AG restarts are needed because a new process starts when the custom extension is assigned to an AG
How can I check if the upload of a custom MIB file is complete? I’ve looked in the Dynatrace community and Dynatrace documentation, but no one has provided a method for “How to check”
