I need to use Vault credential (USERNAME_PASSWORD or CERTIFICATE) through API.
I successfully got vault details (api/v2/credentials/<id>) (doc), but I didn’t find any documentation related to how “get vault details”, like username/password or certificate ?
That is by design, once created entries in the credential vault they are only ‘accessible’ by the extensions, synthetic monitors, and apps that use them they are not available in clear text via UI or API. They can only be overwritten.
“You can see the ID and properties of a credential, but credential content can’t be viewed; it can only be overwritten. The contents of credentials are visible only to the synthetic monitors, apps, or ad hoc functions referencing them.”
Thank you for your answer. I thought that “Read credential vault entries” credentialVault.read permission might allow Vault read. Do you know if this philosophy might be more permissive in the future, or that is something that won’t change ?
The reason for it being not planned should still apply. Additionally, the integration with external vaults mentioned in that older post is now available for several:
