Viewing hosts on Smartscape without OneAgent installed on them
Hi community, I have a question, on my SmartScape I can see 1000 host but for example 250 does not have OneAgent installed, how I can show this information on a (report, metric or dashboard)?
Hey Jorge,
You can use the following API call to get a list of hosts in your environment. To get monitoring candidates you need to set the “showMonitoringCandidates” parameter.
Hosts API - GET all hosts | Dynatrace Docs
Once gotten you can then import and visualize the data in excel or other platforms. Otherwise, as far as I know the smartscape is the only way to visualize these monitoring candidates in Dynatrace at the moment.
Hope this helps!
Hi @Jorge3229,
Or myabe you can use the Alanata a.s., Slovakia, extesnions Nagios or Zabbix if you use one of them. Use these extensions you can enrich the AI engine the Nagios and Zabbix alerts information and of course you can see the zabbix or nagios hosts in the samartscape.
Zabbix Integration | Dynatrace Hub
Nagios Integration | Dynatrace Hub
More info can be found at @Julius_Loman if you intrested in.
I hope it helps.
Best regards,
János
