Virtual Machines not linked
Hi all,
We are testing the integration between Dynatrace and VCenter and some on the virtual machines that appear in the rigth side of the ESXi view on the interface are clickable while others are not.
None of them have oneagent installed.
Does anybody knows why ¿?
Thanks.
BR,
Juan
I’m not exactly sure about the reason, but I’ve seen it at one customer and I think was related to some permission problem of the user Dynatrace used to connect to the vcenter.
Thanks, Július. We are checking that reason.
BR,
Juan
Additionally, the VM hosts with link are monitoring candidates (definition) that Dynatrace is visualizing in Smartscape. For the other VMs without the likn, we do not have enough data.
