Vulnerabilities aren't displayed
See below for potential reasons why vulnerabilities aren’t displayed:
Application Security isn’t activated
If the Third-party vulnerabilities page displays Runtime Vulnerability Analytics with About, Gallery, Use cases, and Supported distributions sections, the Application Security feature isn’t activated. To activate Application Security, contact a Dynatrace product expert via live chat.
Runtime Vulnerability Analytics isn’t enabled
  • If the Third-party vulnerabilities page displays Enable Third-party Vulnerability Analytics with a Configure option, the Application Security feature is activated but third-party vulnerability detection is not enabled. For instructions, see Get started with Runtime Vulnerability Analytics.
  • If the Code-level vulnerabilities page displays Enable Code-level Vulnerability Analytics with a Configure option, the Application Security feature is activated but code-level vulnerability detection is not enabled. For instructions, see Get started with Runtime Vulnerability Analytics.
No software components are reported
If no software components are reported, vulnerabilities aren’t displayed on the Third-party vulnerabilities page. Make sure that the necessary OneAgent features have been confirmed.
To confirm the OneAgent features
  1. In the Dynatrace menu, go to Settings.
  2. In Preferences, select OneAgent features, and then filter for Software component reporting.
  3. Enable any disabled feature in the list.
    Note: For OneAgent versions earlier than the technology-specific version, besides enabling the disabled features, you also need to enable Activate this feature also in OneAgents only fulfilling the minimum opt-in version in the Details of each feature.
  4. Select Save changes.
