What are platform tokens?
How do I use them?
Platform tokens are user bound tokens that allow a user to interact with the platform services in the reigns of his permissions. They are intended to allow a user to interact with the Dynatrace API and to consume the data which he would normally see on the UI.
Every user can create platform tokens in the account management portal:  My Platform Tokens | Account Management
Are these platform tokens meant to replace personal access tokens? Today we have some cases where a team may want to ingest logs but PATs don’t have the available scope (logs.ingest) so we create a standard api token for this. Are platform tokens meant to be replacement here?
@Jon2  HELP!!! I have DT non-prod access as a Standard user yet im unable to see create platform token option under account management → Platform tokens . I have enterprise given Dynatrace access. Will access level as DT_Champion_User has platform token creation enabled?
@Hakeem replied to your query here
@Hakeem ,
what @p_devulapalli said. The other unlikely reason would be that your Account Admin has created an explicit custom policy with “DENY platform-token:tokens:write;” and assigned it one of the user groups you belong to.
