What are some key benefits of Dynatrace and ServiceNow integration?
Hello experts, I am trying to gather some very high level value points for Dynatrace and ServiceNow Integration. May I know some top 3-5 use cases that my enterprise can achieve with this integration.
I would point out those on our official docs:
Dynatrace ServiceNow integration is a two-way integration that:
  1. Pushes incidents from your Dynatrace environment to your ServiceNow instance.
  2. (Optionally) Pushes all single events of a detected problem to the ServiceNow ITOM event API.
  3. (Optionally) Pulls host, process and service information from Dynatrace through a scheduled job within your ServiceNow instance.
You can find it here: https://www.dynatrace.com/support/help/setup-and-configuration/integrations/third-party-integrations/problem-notification-systems/servicenow-integration/
Hope it helps!
Hello @arturo_mondelo
1- You will be able to manage the data by examining the frequencies of the incidents and the open times of each one.
2- You will be able to identify the impacts and classify them, in this way you can pass all these incidents to the DEV for their improvement.
3- On the business side you will have fewer errors since you will be repairing them. In the end, you will have a better quality product on the user side.
Best Regards!
