What are the best use cases for Davis forecasting
Hi ,
I am working POC for davis forecasting capability. I built workflow   which take last week data points of historical resource utilization ( disk , CPU) and predict about upcoming week. Apart from  Disk and CPU , what are other best use cases  can be used to try this forecasting.
I faced some challenge like  Davis analyzer works  with dql query to take historical data points and grail is not having all type of metric data ( Front end metrics , network , DB connections failure related metric). Grail is not having  keys for DT’s built in metrics.
Can somebody guide me how can try more use cases considering grail limitations. Please help on this.
Regarrds,
Heramb Sawant
Hi!
First of all,  I suggest to give a read to this docs page, where there is also an example:
In general, the main point is that the data should be on grail (if you want to use DQL, with JS code you can basically what you want - Forecast with Dynatrace Intelligence | Dynatrace Developer) and should be convertable to a timeseries.
