what metrics displays disk utilization of disk path in linux host for the command df -k
IMO you can try and play around with the metrics @AntonPineiro point to, put them together in a dashboard, something like:
builtin:host.disk.used:filter(and(or(in("dt.entity.host",entitySelector("type(host),osType(~"LINUX~")"))))):splitBy("dt.entity.host","dt.entity.disk"):names:sort(dimension("dt.entity.host.name",descending))
+ builtin:host.disk.avail:filter(and(or(in("dt.entity.host",entitySelector("type(host),osType(~"LINUX~")"))))):splitBy("dt.entity.host","dt.entity.disk"):names:sort(dimension("dt.entity.host.name",descending))
builtin:host.disk.free:filter(and(or(in("dt.entity.host",entitySelector("type(host),osType(~"LINUX~")"))))):splitBy("dt.entity.host","dt.entity.disk"):names:sort(dimension("dt.entity.host.name",descending))
and get the follows
And also upgrade it to a new dashboard
HTH
Yos
@Yosi_Neuman thank you for your answer.
Is it possible to view this data in dynatrace by default instead of dashboard creation?
Not sure that I understand your question but take a look at the analyze disk part of hosts classic
Or add the Disk Analytics extension and check its dashboard
HTH
Yos
@Yosi_Neuman Thanks for your answer
Can this table be shared as data to users via email on a sheduled time?
I would suggest you checking Notebooks + Workflows using Grail.
Best regards
