When I tried to configure anomaly detection for Infrastructure, I found that setting items have two alternatives, that is, they are “automatically” and “based on custom settings”.
The latter is easy to understand for me because this just means I can configure thresholds for infrastructure monitoring manually.
About the former, it is difficult for me because this “Automatically” seems to different than what I expected.
Here, I recognize “Automatically” as “automatically defining baselines”.
However, according to the page below, the term “Automatically” in the view of “Anomaly detection for infrastructure” seems different from it.
https://www.dynatrace.com/support/help/problem-det…
I think this page says that automated baselining is not available for infrastructure monitoring and only static threshold is available.
On the other hand, when I go to “Anomaly detection for applications” view, I can choose “automatically” as the automated baselining option for applications.
Then what does “Automatically” in the view of “Anomaly detection for infrastructure” mean?
Does this mean that build-in static thresholds are used in the setting of infrastructure thresholds?
If my understanding is correct, it feels a little strange for me because the similar term has a different meaning in a similar view.
Kohei Saito
