I’d like to know the meaning of “Problem ID” as seen in “Problems”.
When I go to “Problems”, I can see various problems in the list and each problem has a “Problem ID”.
What I mean here by “Problem ID” is different from a uniquely defined ID for each problem.
This is an example image for “Problems”
Like the above image, “Problem ID” of this problem is “474”.
This “Problem ID” seems not unique ID for each problem but something like ID for grouping or categorising because the same number occurs again and again.
In addition, each “Problem” seems to have the unique ID in the URL parameter like the following.
pid=0123456789_9876543210
Note) Actually, this number has larger digits.
Then, what is the "Problem ID "?
If this means something like ID for grouping or categorising, what are the criteria for grouping?
Kohei Saito
