What encryption is used between a Dynatrace Managed Cluster and Mission Control?
Dynatrace Managed cluster and Mission Control communicate over HTTPS, specifically with TLS 1.2. The certificate (SHA-2) has a 2048 bit RSA key used for the key exchange.
The accepted encryption standard for encrypting the data traffic is AES256.
Update:
You can always check up-to-date information by verifying SSL of Mission Control main domain: mcsvc.dynatrace.com.
For example:
Outputs:
Encryption key: RSA 2048 bits (SHA256withRSA)
The only supported protocol is: TLS 1.2
Cipher suites:
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 ( 0xc02f) ECDH secp256r1 (eq. 3072 bits RSA) FS128 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 ( 0xc027) ECDH secp256r1 (eq. 3072 bits RSA) FS WEAK128 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 ( 0xc030) ECDH secp256r1 (eq. 3072 bits RSA) FS256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 ( 0xc028) ECDH secp256r1 (eq. 3072 bits RSA) FS WEAK256
and many many more detailed information if you are interested.
