Hello
In most cases I notice: when you need manual instrumentation, use Otel.
So what is the status of the oneAgent SDK? Should this not be the first choice?
KR Henk
Hello
KR Henk
Hi @henk_stobbe ,
We recommend using the OneAgent SDK for instrumentation because it is fully supported and optimized by Dynatrace, ensuring robust integration with continuous technical support and updates. Based on my understanding, the following points reflect my perspective in response to your question:
While OpenTelemetry offers certain advantages, the OneAgent SDK remains the preferred choice for secure and reliable integration with Dynatrace, ensuring optimal performance and support.
Thanks for the clear and extensive answer. very useful!
KR Henk Stobbe
