How does real-time debugging in production environments compare to traditional debugging approaches?
What is Dynatrace Live Debugger?
TL;DR: Live Debugger is a Dynatrace third-generation app that lets developers capture real-time debug snapshots from the backend of running applications, with ad-hoc, full-stack, code-level access from either the IDE or a web interface. It works across any environment - Dev to Production, bare-metal to Kubernetes - and pulls integrated snapshots, logs, and traces together so you can reach root cause faster, including for remote, distributed, open-source, and third-party apps.
The Live Debugger 3rd gen application helps developers capture real-time debug snapshots from the backend of their running applications. This allows them to get the root cause faster with ad-hoc access to their code wherever itโs running, from Dev to Production, from bare-metal to Kubernetes:
Instantly capture full-stack debug data from any line of code directly from both your IDE and a web-based interface.
Get the required data to fill Observability gaps in any environment, from dev to prod, in one click.
Easily debug remote, distributed, open-source, and third-party applications.
Get a holistic view of your app with integrated snapshots, logs, and traces.
Great and concise explanation
