What is the easiest way to grant my users access to Dynatrace?
Can you use SAML authorization to map groups from your IdP into Dynatrace?
Since your Dynatrace comes pre-configured with default groups, one simple way to get started is to assign your users to these default groups. For example, the default “Log viewer” group has already been granted the necessary permissions to allow group members to read log records.
Alternatively, SAML authorization through security group claims can be leveraged to configure the mapping of groups from your IdP into Dynatrace.
