When session is not recorded, what we should check on the browser?
When session is not recorded, please check the following 2 points on the browser.1. Javascript agent is injected and loaded
Check the page source that JavaScript code is present and that it loads ruxitagentjs_* with 200 OK with valid contents (not empty).
Then,  on browser developer tool, check if the following 2 Javascript agents should be loaded: normal js agent with feature hash Q, and a separate js agent with feature hash D like:
  • ruxitagentjs_ICA2Qfhqrx_10168190402130100.js
  • ruxitagentjs_D_10168190402130100.js
2. rb_ beacons are sent back successfully
On browser developer tool, check the session replay rb_bf POSTS (Content-Type : application/octet-stream) are sent with a 200 response code and successful response body: e.g., OK(nginx)|name=ruxitagentjs|featureHash=ICA2Qfhqrx|version=|buildNumber=10168190402130100|lastModification=1554225766831
On occasion, WAFs/firewalls/Load balancers will block these beacons.
I would also suggest for RUM troubleshooting, the session with @Julius_Loman & @andreas_grabner
