When should I add PGR?
When do I need to add Process Grouping Rules?
There are two main use cases:
  • Fine-tune the default built-in grouping rules to merge or split processes.
  • In case Dynatrace doesn’t recognize a technology, you can create a PGR rule to recognize it properly and group it in a well-structured way.
