Activeagte default execution plugin seems to be a minute, how can I change it to 30 seconds?
You cannot change the frequency of the plugin execution, and even if you could the Dynatrace Database would aggregate the data to one datapoint per minute anyway.
You can have the plugin send data less often by writing a counter in the plugin, but it will make the charts look ugly with gaps in them, and the AI would not use the data for metric anomalies.
Mike
