Where oneagent must be install? in all servers or just in appserver?
My recommendation would be to install on all servers. If the server has processes that Dynatrace can monitor at a code level (eg. Java, Tomcat, Apache, .NET etc.) then use fullstack mode to get that code level tracing visibility.
If the server doesn’t have processes Dynatrace can trace at a code level (eg. database servers, email servers etc.) then toggle the agent into “infrastructure only” mode.
If you get this wrong, you can always adjust the monitoring mode after installation.
OK , thank you
