Which CA authority issues Dynatrace default SSL certs
We are in the process of acquiring Dynatrace “the SaaS & Managed” product and were looking at SSL Certificate requirement and I have a question.
My company has a list of trusted CA authority for the SSL certs that we use, and I am trying to identify Who the CA authority is that issues the SSL cert that is used by default when Dynatrace ActiveGate is installed Can someone help?
Godfrey
Can you clarify if that’s for Dynatrace Managed or SaaS ? And for Environment AG or Cluster AG?
We are looking at both the SaaS and the Managed product; therefore we will be using both Environment AG and Cluster AG
For Dynatrace Managed:
  • Cluster AG - can use SSL certificate provided by Dynatrace via Let’s Encrypt CA; or can use any other provided by a user
  • Environment AG - by default self-signed cert; can use any other provided by a user
For Dynatrace SaaS:
  • Environment AG - as for Managed
more about providing SSL cert: Custom SSL certificate for ActiveGate — Dynatrace Docs
Hi Radoslaw,
Your quick response is very helpful.
Thanks you,
Godfrey
