Which connection type is better for my AWS account with Dynatrace:- Role-based authentication or Key-based authentication ?
I want to know in terms of on dynatrace billing and security.
Moved to the Dynatrace Open Q&A forum where it;s likely to get an answer.
Hello @saurabhkumar_pa,
Here you can check out the documentation article about the access methods for AWS:
Set up Dynatrace Managed for AWS monitoring
As you can see there, we’re recommending as a best practice use of temporary security credentials (IAM roles) instead of access keys and disabling any AWS account root user access keys.
