Which license should we have when DB Monitoring with plugins?
I know that we can monitor some DBs such as PostgreSQL and MS SQL with plugins.
・PostgreSQL
https://www.dynatrace.com/support/help/technology-…
・MS SQL
When we want to monitor these DBs with plugins, which license do we need, Fullstack or Cloud-infrastructure?
I think that we need the latter because, in this case, we doesn’t monitor applications which needs some code injections for monitoring.
Kohei Saito
Correct, infrastructure is sufficient.
