Why are API tags considered as manual tags?
Dear All,
Babar
Do you have some example to understand it better?
Best regards
Hello @AntonPineiro
I applied the tags on the Pods through API, as this is not possible through the automatic tag, and those are considered manual.
Babar
Dear Babar,
API tags are considered manual tags because when you use the Environment API v2 “Monitored entities - Custom tags,” you are assigning tags to specific entities manually. This is in contrast to automatic tagging, which can be achieved using the Environment API v2 “Settings - Objects” with the schema ID builtin:tags.auto-tagging. Automatic tags are generated based on predefined rules and do not appear as manual tags.
Manual API schema ID
Auto Tag schema ID
Use Setting Object API
