Why are logs still missing after enabling Log monitoring?
Log monitoring is turned on by default, but this setting might have been changed.
  1. Ensure that OneAgent log ingestion is turned on in your Dynatrace environment: Go to Settings > Monitored technologies and make sure that Log Monitoring is set to Enabled.
  2. Ensure the OneAgent instance has the log feature turned on. If OneAgent was installed with --set-app-log-content-access=false, redeploy OneAgent in your Kubernetes cluster with --set-app-log-content-access=true. See Customize OneAgent installation on Linux for more details.
For additional guidance, see Troubleshooting Log Management and Analytics.
