Why is my Synthetic ActiveGate shutting down?
Summary: This article explains why a Synthetic‑enabled ActiveGate may show a ‘shutting down’ status, and so not run any monitors, and provides troubleshooting steps covering version mismatches, security software interference, Chromium issues, missing libraries, and OS‑specific causes.
Synthetic Engine Status
When checking the health of a Synthetic-enabled ActiveGate, the Deployment Status > ActiveGates page is one of the first places to look. This page provides helpful information on the current status of the ActiveGate, the enabled modules, the versions in use, and whether it is running.
This article contains troubleshooting steps for when an ActiveGate with Synthetic enabled is running, but the Synthetic Engine Status shows as shutting down, as seen in Deployment Status > ActiveGates.
This situation occurs when there is a problem starting the Synthetic module. If the self-diagnostic test fails, the Synthetic module will restart in an attempt to run again. If the restart does not resolve the startup problem, the Synthetic module becomes stuck in a loop of going offline, running the self-diagnostic test, shutting down and going offline again.
Troubleshooting
ActiveGate and Synthetic Module mismatch
Check if the Synthetic and ActiveGate major versions match. In the image above, they don’t.
If the major versions differ, check this article to see why the Synthetic module failed to update.
Security software
Antivirus, anti-malware and endpoint detection software can adversely affect Dynatrace Synthetic monitoring capabilities. The security software might block the Chromium browser or Dynatrace processes responsible for executing synthetic monitors, cause Synthetic-enabled ActiveGate installation and update failures, interfere with network communication, and impact the reliability of measurements.
If the machine has any security software installed or running
  • Exclude the directories and processes listed here.
    We recommend working with the antivirus or anti-malware software vendor to find the correct settings.
    • On Windows, if the complete list has already been excluded, you may need to exclude the instance that the ActiveGate uses specifically, C:\Program Files\dynatrace\synthetic\Chrome-bin\chrome.exe is the default path.
  • Disable behavioral monitoring or kernel-level hooks
    Behavioral monitoring or kernel-level hooks can affect how Chrome interacts with system libraries. As a result, even excluded processes can indirectly cause access violations or heap corruption, especially during non-standard operations within Chrome, such as running Synthetic Tests.
    An example of this is EDR, Endpoint Detection and Response.
  • If the exclusions and disabling behavioral monitoring don’t change the behavior, try disabling/ removing the machine’s security software to confirm if the issue occurs without it.
  • For Windows machines, reboot the machine.
Chromium
Old version of Chromium
On Linux machines, a common cause of this behavior is an old version of Chromium. Dynatrace supports Chromium versions, which are no more than two versions behind the latest Dynatrace-supported version for a specific ActiveGate release. Chromium can be manually updated using the instructions here.
Chromium version shows as 80.0.0000.00
If Chromium version shows as 80.0.0000.00, then the Synthetic Module can’t recognise the version.
For Linux machines
  1. For Ubuntu Server 20.04 and 22.04, with the ActiveGate upgraded from ActiveGate version <1.331 to 1.331 or higher. Starting with ActiveGate 1.331, Chrome for Testing replaces Chromium.
    1. If possible, reboot the machine.
    2. Manually install the dependencies and Chrome for Testing, using steps 1 and 2 here.
  2. For Ubuntu Server 20.04 and 22.04 with an ActiveGate version earlier than 1.331, these ActiveGates use snap.
    2. Follow these steps to uninstall and reinstall Chromium (replace the package with the expected version from here)
      sudo snap remove chromium
      curl --remote-name https://synthetic-packages.s3.amazonaws.com/Chromium/snap/chromium-127.0.6533.88-2923.tgz
      tar xzf chromium-127.0.6533.88-2923.tgz
      sudo snap ack chromium.assert
      sudo chown -R root:root /tmp/snap-private-tmp
      sudo snap install --devmode chromium.snap
      sudo chown -R dtuserag:dtuserag /tmp/snap-private-tmp
    3. Restart the vuc.service, or, preferably, reboot the machine
      sudo systemctl restart vuc.service
  3. If SELinux is enabled, reinstall Chromium after setting SELinux to permissive mode.
  4. If the OS was recently updated by a major version (for example, from RHEL 8 to RHEL 9), uninstall and reinstall the ActiveGate.
  5. Check the vuc_browser.log for the following error
    /opt/dynatrace/synthetic/browser: symbol lookup error:
    1. undefined symbol: mpg123_param2
      If the full error contains
      /opt/dynatrace/synthetic/browser: symbol lookup error: /lib64/libopenmpt.so.0: undefined symbol: mpg123_param2
      Run the following command to get the latest update of the library “mpg123-libs” (version 1.32.0 or newer is required)
      sudo dnf install mpg123-libs
    2. undefined symbol: drmSyncobjEventfd
      /opt/dynatrace/synthetic/browser: symbol lookup error: /opt/dynatrace/synthetic/browser: undefined symbol: drmSyncobjEventfd​
      install libdrm-2.4.123-2.el9.x86_64 or newer
      sudo dnf install libdrm-2.4.123-2.el9.x86_64
    3. undefined symbol: amdgpu_cs_ctx_stable_pstate
      symbol lookup error: /lib64/libgallium-24.2.8.so: undefined symbol: amdgpu_cs_ctx_stable_pstate
      Install the relevant library.
      sudo dnf upgrade mesa* libdrm* -y
  6. Check the vuc_browser.debug.log for the following error
    error while loading shared libraries​
    This means a library that Chromium depends on is not installed on the machine.
    Here are a couple of examples
    2025-07-22T07:26:14,779Z DEBUG [v=5] [BM-gobbler-3] ChromeGobblerLogger: /opt/dynatrace/synthetic/browser: error while loading shared libraries: libcups.so.2: cannot open shared object file: No such file or directory
    2025-07-24T07:30:33,010Z DEBUG [v=5] [BM-gobbler-3] ChromeGobblerLogger: /opt/activegate/synthetic/browser: error while loading shared libraries: libdouble-conversion.so.3: cannot open shared object file: No such file or directory
    You’ll need to search the internet for the RPM containing your Linux flavor’s library. For instance, if you’re missing libdouble-conversion.so.3 on a Red Hat 8 machine, you would search for ‘libdouble-conversion.so.3 el8’. This will provide links to suitable download pages, like https://rpmfind.net/. You can then check the name of the RPM containing this library.
    In this case, the library is double-conversion-3.1.5-1.el8 from the Fedora link name, but you may need to select the link to check. This is from the RPMfind link,
    You can then install this on your machine using
    sudo dnf install RPM_NAME​
    where RPM_NAME is the link without .rpm, so for this rpm it would be ‘double-conversion-3.1.5-1.el8.x86_64’
    sudo dnf install double-conversion-3.1.5-1.el8.x86_64
For all OS
See the Security software section. It is likely that an antivirus is preventing Chromium from starting up as expected.
Log Messages
Download the logs from the ActiveGate using the ActiveGate diagnostics feature; otherwise, you can check on the machine itself in /var/log/dynatrace/synthetic or %PROGRAMDATA%\dynatrace\synthetic\log.
Check the vuc-status.log for DiagnosticResultsHolder and see if any modules failed to be operational. There are four to check: MULTIPROTOCOL, HTTP, HTTP_SCRIPT, and BROWSER.
Where the module start up is successful, you’ll see isOperational=true, for example
2024-09-18T01:10:53,190Z [DiagnosticResultsHolder]
 browser = `DiagnosticResultsChangedEvent[moduleName=BROWSER, diagnosticCasesResult=DiagnosticCasesResult[isOperational=true, cases={BROWSER_MAIN=DiagnosticCaseDetail[isAvailable=true], BROWSER_FALLBACK=DiagnosticCaseDetail[isAvailable=true]}]]`
And where the module startup is not successful, you’ll see isOperational=false, for example
2024-09-23T07:40:25,237Z [DiagnosticResultsHolder]
    browser = `DiagnosticResultsChangedEvent[moduleName=BROWSER, diagnosticCasesResult=DiagnosticCasesResult[isOperational=false, cases={BROWSER_MAIN=DiagnosticCaseDetail[isAvailable=false]}]]`
Depending on which modules were unable to start up, check the relevant logs for ERRORs and WARNINGS
  1. for HTTP Monitors, vuc-http.log, vuc-http.debug.log, and additional log files with stdout/stderr output in the executors subdirectory
  2. for Browser Monitors, vuc-browser.log and vuc-browser.debug.log
    1. Running as root without --no-sandbox is not supported
      . The issue is likely related to the user running the Synthetic Engine. This should be run by dtuserag and not root. Reinstalling the ActiveGate will correct this behavior.
    2. Failed to create directory
      The issue is likely related to the location of the TEMP directory.
      For Ubuntu with snap, version 20+, the temp directory path must begin with /var/tmp, for example, TEMP=/var/tmp/syn. Also, Dynatrace requires write access to /var/tmp to install Chromium snap packages. See note in docs
    3. No usable sandbox! If you’re running on Ubuntu 23.10+ or another Linux distro that has disabled unprivileged user namespaces with AppArmor
      Although this message mentions Ubuntu and AppArmor, it can be seen on any Linux distro with or without AppArmor. This behavior is often seen when system hardening measures have been applied and are too restrictive.
      1. Verify config_user_ns and max_user_namespaces kernel settings
      2. If AppArmor is used, confirm that AppArmor settings allow the use of unprivileged namespaces
  3. for NAM monitors, vuc-multi.log, vuc-multi.debug.log
Windows Machines
  1. Check if the OS is supported.
    For instance, we don’t support Windows 2012 (R2), and from 1.263, we found that this causes the VUC to show this shutting down status. This is due to Google stopping support for Chrome on Windows 2012 (R2) with Chrome 109. Chrome browser system requirements - Chrome Enterprise and Education Help
    In Windows Server 2025, some of the tools used by the ActiveGate are deprecated. So currently this is not supported.
  2. Check if any recent Windows updates have been applied, like this one that prevented Chrome from starting.
  3. Reboot the machine
  4. If any antivirus or anti-malware applications are running on the ActiveGate machine, see the Security software section above.
    Note: Since Chromium 129, Antivirus settings that previously allowed Chromium to be installed and run have been found to be insufficient, and the complete list from here must be excluded.
    For the Chrome process, you may need to be very specific and exclude the instance ActiveGate uses; C:\Program Files\dynatrace\synthetic\Chrome-bin\chrome.exe is the default path.
What’s Next
If none of the previous steps resolved the issue, open a chat and provide the Support Archive from the ActiveGate with the troubleshooting steps you have already completed.
What to read next:
Synthetic Troubleshooting Map
Create a private synthetic location
Configure browser monitors in Classic — Dynatrace Docs
Why does Chromium show as failed or skipped in Deployment Status when it is up to date?
Private Synthetic locations: ActiveGate installation/update failed because of missing dependencies
Dear Hannah,
We have the problem with ‘Chromium version shows as 80.0.0000.00’ again and again.
It happens about once a month on different Ubuntu ActiveGates.
Is there already a permanent solution for this available?
Best Regards,
Elmar
Hi Elmar,
thanks for the feedback. I wasn’t aware of this being a regular occurrence for customers; rather more a one-off to have to reinstall Chromium. Can you create a support ticket and we’ll check further on it?
Thanks, Hannah
Thank you for the Tips :+1:
Thanks for the post.
Hi @HannahM,
Thank you for sharing the tips on troubleshooting Synthetic ActiveGate issues.
We are currently facing a similar problem where the Synthetic Engine health check is showing as Offline. Our Dynatrace Managed environment is fully offline, and we are attempting to install the Synthetic ActiveGate on a Windows Server 2022 host that does not have internet connectivity.
Since the environment is offline, we are using the installation packages provided by Dynatrace as part of the cluster upgrade bundle. Our current cluster version is 1.326.100, and the ActiveGate version is 1.325.24. We have also tested the installation with antivirus software disabled, but the issue persists.
The ActiveGate appears unable to  download additional capabilities, such as the Synthetic module. At the end of the installation, the launcher displays the message: “Additional capabilities: Synthetic is not available on the server.  However, Chromium cannot be installed manually, as it is bundled with the Windows package. Despite this, the Synthetic Engine health check remains offline.
When we attempt to install the same version of the Synthetic ActiveGate on a different Windows machine with internet access, the installation works fine.
We have already opened a support case and uploaded the required diagnostic archive. The support ticket number is #595568. Any assistance or guidance you can provide on this issue would be greatly appreciated.
Thank you in advance for your help.
@Supriya_K , Thanks for letting us know. The Synthetic module is downloaded from the cluster rather than the internet. However, if that were the case, I wouldn’t expect to see a message saying that the Synthetic module was shutting down, since it wouldn’t be installed. This guide is better for problems with installing/ updating the Synthetic Module. I’m discussing this with support. Let’s communicate on your ticket.
@HannahM ,
Thanks for your response.
I just wanted to inform you that the issue has now been resolved. The synthetic package was missing on the cluster from the bundle, and we found that the synthetic module was not present on the cluster nodes, which was causing the issue. We’ve since uploaded and reinstalled the synthetic AG, and everything is now working as expected.
