This fails:
fetch logs
| filter matchesPhrase(host.name, “carn”) // fail
and matchesPhrase(log.source, “rmwfeapi”)
and matchesPhrase(content, “Unable”)
| fieldsKeep timestamp, host.name, content, log.source
This works:
fetch logs
| filter matchesPhrase(host.name, “carn*”) // why is wildcard required?
and matchesPhrase(content, “Unable”) // this works!
What is it about host.name that matchesPhrase doesn’t work as expected? It can find “Unable” in the middle of content but it can’t find “carn” at the beginning of host.name? Why not?
MatchPhrase should match the exact value you are querying.
So I am assuming your host name is not only carn, but carn’something’.
Can you confirm?
If you want to filter by hostname with just a piece of the name without using the wildcard, you can use the contains instead.
My message says “carn*” works and “carn” does not. If “carn” was the server name “carn” would work. I think this is a DQL bug.
That’s not a bug, that’s just how matchPhrase works:
It should match the phrase you are looking for. If you want to get a string piece only, you should use “contains” instead.
Please let someone from Dynatrace respond thanks.
because word boundaries count
