Windows System consuming 80% + of CPU Resource, how to further troubleshoot in Dynatrace?
(other than asked customer to open task manager to have a look)
Best,
Wai Keat
Best,
Wai Keat
Thatâs a good question. I donât think you can break âWindows Systemâ out further in Dynatrace.
Yep, which makes alerting about it a bit problematic. We also often see âPacket retransmission rate for process Windows System on host asdf has increased to 10 %â. Seems like the best option is to just suppress these alerts, because thereâs nothing you can do with that information. âŚOr if someone has ideas, do let me know ![]()
One idea might be to look at the Windows logs at the host level in Dynatrace. Might find an indication of something that might be going on. Also, take a look at the number of DNS queries, as it has surprised me in some occasions.
There is a way to figure out which processes are include under windows system from SA.
Go to diagnostic files --> Agent --> logs --> os and open processesSnapshot.log
In this file look for Group name: Windows System, under it you will find all the windows processes that OA collect together.
You will see for each process last CPU val and Virtual memory peak size and can get a clue on which process is consuming more CPU and Memory than others.
HTH
Yos
To get a process snapshot you can enable automatic process snapshots that run based on any of these triggering events or you can run a snapshot manually by selecting ⌠in the Process Snapshots section on a specific host page.
Hi Maximus,
Please confirm that the OneAgent is on the supported version of 1.237 or higher.
Otherwise, if you reloaded the page and the snapshot was not there, please open a DynatraceOne Chat or Support Ticket for further assistance.
The agent version is 1.239.
I have contacted support and this is their answer:
âCould you please update the OneAgent running on the host to at least version 1.251? The version of OneAgent currently running on the host is not supported.
With the release of OneAgent version 1.275, our oldest supported version is 1.251: https://www.dynatrace.com/support/help/shortlink/release-notes-oneagent-sprint-275
The version number next to the process instance snapshot function corresponds to the date on which the function was introducedâ.
That doesnât help me ![]()
Regards
