Hi All,
Currently, I’m working with a legacy system that instrument the traces using OpenTracing. Without using oneAgent is there any way to publish that traces to Dynatrace?
Sasin
Hi All,
Sasin
Hi @sasin , sure is there: OpenTelemetry and Dynatrace — Dynatrace Docs
You will send the data to Dynatrace using rest API (/api/v2/otlp/v1/traces).
Hi @dannemca,
Thank you for the quick response. But the thing is my system(WSO2 API manager) instruments the traces using OpenTracing. I have tried your solution and it is not working without OneAgent.
Oh my bad then, I misunderstood, sorry.
OpenTracing is now deprecated and OpenTelemetry is the new standard. I would highly recommend migrating to OpenTelemetry: Migrating from OpenTracing | OpenTelemetry
An OpenTracing to OTEL shim is available.
Hi Sasin,
you can use GitHub - tbrandl-dynatrace/wso2-apimanager-dynatrace: A custom OpenTracing implementation for WSO2 API manager to use in Dynatrace · GitHub for doing OpenTracing with Dynatrace on WSO2.
Best regards,
Thomas
