Workflow cross-tenant?
We have a workflow which execute DQL queries and send a report with problems opened by email.
Some entities are in another tenant. Do we have a way to get those problems, in another tenant, in same workflow?
Have you try this before?
Best regards
Hi @AntonPineiro ,
Yes, this is possible. You can add a Custom JavaScript task to the workflow, call the remote Dynatrace environment, and execute a DQL query to retrieve the required data.
You can use the same approach described in the following post for further details:
https://community.dynatrace.com/t5/DQL/How-to-retrieve-data-from-another-tenant-and-display-in-chart/m-p/293423
Please ensure that the required access token and permissions are configured for the remote environment.
Hamdy
Thank you so much! Dynatrace support has confirmed this is way to go.
Best regards
Thank you. Glad to hear that!
