Workflow event trigger not saving
I’m trying to create a workflow using an event trigger. When I query past events, the query works fine. However, when I save, I get an error saying my query is incorrect.
This is my query:
matchesPhrase(dt.entity.http_check, “HTTP_CHECK-F724611E130DE727”) and result.statistics.duration > 10000
Error message: Reason: Invalid DQL query: token recognition error at: ‘>’ at 1:98
Any solutions for this? Thanks
Currently, in the event trigger DQL matcher, not all conditions are applicable. The “greater than” (>) condition is not supported at this time.
