How can I pass response of one task to input of another task?
Hello @Sahil2308,
In this documentation article, you can check out the expression reference for result() which will allow you to access the result of a preceeding task within the workflow:
Introduction to workflows - Expression reference
Thanks @MaciejNeumann ![]()
Is it possible to access the first task’s logs( details from Log pane) in 2nd task using javascript??
