Workflows set as Public access are having view and edit access for "Monitoring Viewer" users. Is it the expected behavior ?
We have the workflows which are set as public are viewable and editable by the “Monitoring Viewer” users.
They are the read only users in Dynatrace and not suppose to edit any of the workflows.
Ram
Hello @RamkumarTIH you can configure your expected access using policies. Role Based Access like Monitoring Viewer is different from Attribute-Based Access Control is more granular. With this you can control the expected behavior of Dynatrace permissions.
Hi @DanielS  - Does it mean by default “Monitoring Viewer” will be able to edit the workflows set as public ?
Do i need to create specific Attribute based access to restrict the workflow edit access for “Monitoring Viewer” users ?
Hi @RamkumarTIH I don’t have a Vanilla tenant to check basic access but I can assure you that if you set a correct set of ABAC policies you can restrict all of this items:
  • automation:workflows:read
Grants permission to read workflows
  • automation:workflows:write
Grants permission to write workflows
  • automation:workflows:run
Grants permission to execute workflows
  • automation:workflows:admin
Grant admin permissions for workflows.
  • automation:rules:read
Grants permission to read scheduling rules
  • automation:rules:write
Grants permission to write scheduling rules
  • automation:calendars:read
Grants permission to read business calendars
  • automation:calendars:write
Grants permission to write business calendarsHope it helps.
Thanks @DanielS
I have assigned the in-built “Standard User” policy to the Operators.
Looks like below one is mandatory for users to access new UI..
//AppEngine
ALLOW app-engine:apps:run, app-engine:functions:run, app-engine:edge-connects:read;
Have created a custom Denial policy with the rules below and assigned to the group as i am unable to modify the default Standard user policy. Now Operators are able to access both old UI and new UI but with restriction to Workflows App and few others as per DENY statements.. Thanks for the help
//Davis
DENY davis:analyzers:read, davis:analyzers:execute;
//Davis Copilot
DENY davis-copilot:conversations:execute, davis-copilot:nl2dql:execute, davis-copilot:dql2nl:execute, davis-copilot:document-search:execute;
//Grail
DENY storage:bucket-definitions:read;
DENY storage:fieldset-definitions:read;
DENY storage:filter-segments:read, storage:filter-segments:write, storage:filter-segments:delete;
//AutomationEngine
DENY automation:workflows:read, automation:calendars:read, automation:rules:read;
DENY automation:workflows:write;
DENY automation:workflows:run;
//Extensions
DENY extensions:definitions:read;
