z/OS monitoring went down after AG update
Question
The z/OS monitoring went offline after updating the zRemote ActiveGate. Why is that happening?
Answer
There are many possible reasons why the z/OS monitoring went offline. The first troubleshooting step you need to do is to check the versions.
As stated in this article, zRemote, zDC/zLocal, and the CICS/IMS Code modules work hand in hand. If you update one component, you must update the others. Else, they will be incompatible with each other.
As best practice, it is recommended that the z/OS monitoring components should be on the same version as the zRemote AG or at least 3 versions lower.
How to check the versions, please visit this page: https://community.dynatrace.com/t5/Troubleshooting/Troubleshooting-your-z-OS-monitoring-Covering-the-basics/ta-p/197961
To uninstall the z/OS code modules: Uninstall the z/OS modules — Dynatrace Docs
To install the z/OS code modules: z/OS installation overview — Dynatrace Docs
Hope this helps.
thank you @jellypuno for sharing this!
