Hello.
My client is using dynatrace managed and i’m trying to implement beacon endpoint for oneagent type and i’m experiencing 204 error code issue. You can see it in those visuals below:
Do you have any idea why this occurs?
I recommend create a support ticket.
This is a bug, and it manifests only if the Cluster Management → Settings → Cluster ActiveGate URL is empty. Obviously, it can be empty, but the new General settings → Beacon endpoint page is not ready for such a situation.
The workaround is to fill Cluster Management → Settings → Cluster ActiveGate URL literally with any URL, it can be even https://www.test.com … If you want to fill it with realistic data (but still unused), add your ActiveGate URL (of any type): https://[Active-Gate-Domain]:9999
Here is heads-up post about this issue.
thank you for your reply but i could not find ‘‘Cluster Management’’ in my demo environment (its saas) may you share a screenshot which you show it exact place in ui? so i will be able to guide my client. Thank you again!
I’m sorry for not mentioning this - it’s related only to Managed.
The official Head-us post is here.
