ActiveGate as a beacon forwarder in SaaS deployment
Hi Folks,
I need help in configuring AG as beacon forwarder.
I have enabled the beacon forwarder module on the AG. Now, to forward the beacon signal for an application, from where do I get beacon URL to add and also where do I need to add that beacon URL under application setting?
Application setting has three options,
  1. Default
  2. OneAgent
  3. Cluster ActiveGate
AK
Can someone please guide on this.
AK
Hello @AK
Are you talking about the Cluster/or Environment AG?
Did you review the below documentation?
Babar
You need to use Configure beacon endpoint for web applications in RUM Classic — Dynatrace Docs
and the URL should be your AG
@PacoPorro, thank you for the response.
Will that AG URL available publicly?
If yes, do I need to do any changes under AG config files?
AK
@Babar_Qayyum, thank you the response. It is environment AG
Network configuration is outside of the Dynatrace configuration.
@pacha @Babar_Qayyum,
Thank you for useful insights. We were able to get the help from Dynatrace support to resolved this.
Following beacon URL need to be used under application setting. provided that, a valid certificate added to ActiveGate  since the communication goes via HTTPS.
https://ActiveGateFQDN/bf/tenantID
https://ActiveGateFQDN/beacon/tenantID
AK
