Use Oneagent as a beacon endpoint to monitor Mobile RUM
My customer have a AppMon, but in few days they are want to migrate to Dynatrace. So in the AppMon, they monitoring Mobile UEM, that to send the beacon is using the URL of web server like this example https://mxx.maybe.co.id/maybeid
Below is the configure of AppMon
Dynatrace is different to monitor Mobile RUM, in the documentation is to monitor Mobile RUM need cluster activegate with public ip. But in this case, my customer can’t give public ip to cluster activegate server. But I found the doc that can be alternative way to monitor Mobile RUM, this is using oneagent as a beacon endpoint. Here is the link : Use OneAgent as a beacon endpoint for mobile applications in RUM Classic — Dynatrace Docs
So when I implement mobile RUM, is it correct to put https://mxx.maybe.co.id/maybeid/dtmb in the instrumented web sever ?
I have it working in the context of an internal custom application. I had some issues that were solved in the thread below. Given what you said, it should work, given that https://mxx.maybe.co.id/maybeid/dtmb is monitored by OneAGent in full-stack mode.
Hey Muhammad,
You are currently using version 7.2.x of the Dynatrace Android Gradle plugin. You have to upgrade to version 8.x, when you migrate to Dynatrace. Fortunately, version 8.x of the plugin is compatible with AppMon 7.2.x. Therefore we recommend, as first step, to upgrade to version 8.x. This documentation section provides an overview on how to upgrade from version 7.2.x to version 8.x.
The main different in the plugin configuration between Dynatrace and AppMon is, that you have to use the property “beaconUrl” for Dynatrace instead on the AppMon property “agentPath” as shown in this example.
Putting the value https://mxx.maybe.co.id/maybeid/dtmb into the “instrumented web sever” form, will only change the Gradle snippet in the “Instrumentation wizard” page. You still have to copy this Gradle snippet (with the applicationId and beaconUrl value) into your build.gradle file
Hi Thomas,
Thanks for the answer btw, I just want to confirm when I have not a Cluster ActiveGate with public IP, it still can monitor the mobile RUM with instrumented web server as endpoint beacon like in the doc right ?
So there is nothing issue when I have not a Cluster ActiveGate with public IP right ? I just want to confirm, because oneagent will installed in the web sever, the web server is using IHS.
Yes, the web server agent will forward the monitoring data.
Yes, no configuration need if oneagent is running, it will just use pass that information to the Managed cluster. Be sure to get the application IDs right.
Hi Thomas,
I have done instrument hybrid application with dynatrace cordova plugin, I try using oneagent as beacon endpoint. The native action is recorded to the Dynatrace UI, but for webview action is not showing.
Is there still any possibility to monitor webview side with oneagent as beacon endpoint ? because when I see in the javascript inline code, there is pointing to the cluster activegate, in this situation my cluster activegate doesn’t have public ip
FYI @Thomas B. do you know if this is already supported?
