When using Openkit in a Managed Environment, there is the possibility of sending the information through a Cluster Activegate, but also through an “Instrumented web server”.
There is not a lot of information out there about this option. Seems we can use a subset of OneAgents running on servers with some webservers:
Hello Antonio. Did it work with an Webserver with OneAgent? And if yes, what did you do beside installing OneAgent on the Webserver? We have a szenario like this and i need to find any documentation… We use Dynatrace Managed.
We do this quite often, just a Full stack OneAgent needed on a supported web server (see Antonio’s link). If it doesn’t work you can reach out to the Dynatrace chat for live help.
Yes, it worked, only with one problem, but that was related to some security configuration on our side. The only restriction is that you can’t do this when OneAgent is in infrastructure mode.
