I’m currently working on a Kubernetes monitoring environment using Prometheus and Grafana. I’m finding that the open source tools have some limitations in providing insights into Kubernetes metrics. I’m looking for a SaaS solution to supplement these limitations.
Does your Product have a dashboard that allows me to view pods that have disappeared(= dead = no longer receiving data) in the past?
How do I filter pods or in this monitor pods that are stuck on terminating status. Keep in mind that terminating status is not part of a pod lifecycle. I have done a lot of searching but i have found any solution. Using FAILED_PHASE is not enough. NB in terminating status you will find that the pod is in running state as well as containers.
I’m curious if your company has a feature that allows me to view pods that have disappeared in the past (i.e., dead = no longer receiving data). If so, can you provide me with any detailed documentation about this feature?
