Hi
I can see the age column related to pods under kubernetes overview of the node
how can i use it to display in dashboard panel to show the uptime of the pods
In order to get that information dashboarded you would have to be able to get a metric to display in data explorer. Please try looking through the kubernetes built in metrics found here, Built-in classic metrics ā Dynatrace Docs.
If there is not a metric for āpod uptimeā it may have to be a custom metric, or you can post this in the Ideas channel for suggesting the creation of such a metric.
i think that if you use builtin:host.uptime maybe works, but i dont know for sure.
You can try create metrics to do this. anyway take a look of this documentation page
Feel free to ask if you got any doubts
Hi @VENKY1544,
AFAIK there is not an OOTB solution. Maybe you can play with Environment APIv2 Monitored entities:
GET / entities provide a list of entities with fist seen and last seen attribute, you can filter only for pods by type(āCLOUD_APPLICATION_INSTANCEā)
or
GET / entities / {entityId} but in this case you should know the individual entity ids.
I hope it helps to start thinking.
Best regards,
MizsÅ
hi @VENKY1544 , did any of the comments above help you? You can accept any of them as solutions if they work ![]()
