I need to create a dashboard for monitor the pods of openshift service. What are the metrics needed for that?
Hello @nam
There are already three preset dashboards available for the Kubernetes. Please have a look into them and then you clone them to modify them according to your need if they do not fulfill your requirements.
Babar
Hi @nam
Here you can find all openshift metrics which you can use to create custom dashboards: Monitor Kubernetes/OpenShift metrics — Dynatrace Docs
Radek
