Account Management API for Subscriptions is blank
I can list groups and environments, but subscriptions returns blank. The status code is 200 and there is no token error.
https://api.dynatrace.com/sub/v2/accounts/<uuid>/subscriptions
I used scope=account-uac-read to generate a token.
Does anyone know what is causing this?
The output shows { “data”: [] }.
Hi @tjay
What license are you currently on with your Dynatrace tenant?
Depending on your license currently, you can try the v1 api and see what the return is:
https://api.dynatrace.com/sub/v1/accounts/<uuid>/subscriptions
Lawrence
Hi @LawrenceBarratt
Thank you for your comment.
We use Host Units, DDU, DEM and ASU.
I tried v1 and here is the result.
https://api.dynatrace.com/sub/v1/accounts/\/subscriptions
{“totalCount”:0,“records”:[]}
Hi @tjay,
Are you on full DPS or classic licensing?
I tested an account in postman and got this result:
Have you input your bearer token  for Authorization?
Lawrence
Hi @LawrenceBarratt
Thank you for your reply.
I believe we use the DPS license. Regarding the bearer token, I do use it. Without it there is an error - Incorrect Authorization header in request.
I tired the GUI example to get the subscriptions.
https://api.dynatrace.com/spec/#/Dynatrace%20Platform%20Subscription/SubscriptionsController_listSubscriptions
For v1 the curl command as follows. I tried v2 as well.
curl -X ‘GET’   ‘https://api.dynatrace.com/sub/v1/accounts/\/subscriptions’   -H ‘accept: application/json’   -H ‘Authorization: Bearer <token>’
