My team uses the on-prem dynatrace dtsaas solution, that generates multiple environments for projects, and we are trying to uncover how to to utitlize the API tokens generated at the cluster level in the “Settings” → API Token. Basically, we can now generate an API token at the cluster level, but I am not sure how to use it in this context. We are hoping their might be some documentation on how to utilize api or at least derive the cluster (management) api … like create, read, update, delete environments.
The cluster management API is in EAP state right now, that’s the reason why we do not have a public API help docu so far. I will reach out to you directly to send you the API documentation.
We will introduce that public help documentation within the next weeks.
Thanks for the documentation heads up, looking forward to using the API.
Is this documentation in the meantime available or can we obtain it somewhere else?
Is there any update in this? I see that there is an API doc there, but no documentation under the documentation part
We are still in the process of moving over all relevant cluster management API endpoints into the API explorer. Next one that you can expect there is the token management endpoint. Should be available in the next releases.
